VHF Radio, Hooks
Published date: December 1, 2019
  • Boat Type: Boat Type
(A) shows the VHF radio we had installed. The guy doing the installation ran into the lower-upper liner problem and decided to just run the power lines outside the wall for a short distance from the upper liner and then into the side of the house battery compartment. It works, and it's not that bad, but I would have done it more cleanly. Also in the bundle of wires is the compass light wire.
The wires from the VHF pass into holes in the wall behind the radio and into the battery compartment with a nice cover so it looks neat. The wires run into the cover parallel to the wall. I have the antenna enter the cover normal to the wall, and run entirely through the various conduits to the through-deck connector by the mast base.
(B) shows some hooks that I glued on to the wall of the liner. They're convenient for hanging small items and have never slipped or come loose. But I made sure the surface was first sanded and then cleaned where I glued them.
(C) shows the aft end of the hook that holds a gear hammock over the galley. These hooks are also glued on. We divided another gear hammock into two pieces and put a small hammock on the starboard side of the v-berth and in the head.
Published by: Heath
Model Year: 1997
Share
Related Mods
  • VHF Antenna
    VHF Antenna
    Instruments - - December 1, 2019
    The VHF antenna cable (B) passes through the deck near the mast base. When you drill you hole for the cable, you have to watch for two things: * Make sure that you drill far enough to the side so that you do not hit the metal backing plate (A). * Mak...
  • VHF Antenna
    VHF Antenna
    This shows where the antenna cable exits the deck. It comes out right next to the conterboard cable without rubbing against it. This end connects with the antenna cable exiting the mast on the same side. To get the coaxial antenna cable to come out t...
  • Compass in Cockpit
    Compass in Cockpit
    I have added a compass in the cockpit. The only thing to watch out for is when you are drilling the hole in the bulkhead, make sure that when you insert the compass, it does not hit the sides of the access compartment behind the bulkhead. The line yo...
