Fuel Line Disconnect Protector
Published date: July 21, 2005
  • Boat Type: Boat Type
One of the most aggrevating problems I was having was accidentally disconnecting the gasline connection fitting to the gas tank. I must have happy feet, because everytime I needed to use the motor to get me out-of-trouble, the engine would die because I has inadvertently rubbed against the gasline fitting with my leg, disconnecting it. The fitting is sticking out where happy feet can easily disconnect it. Ahhhhh. Adrenaline.
Solution - rather than swap the tanks (left tank on the right side, and vice versa to get the fitting out of the cockpit), all you have to do is take a 5" length of PVC pipe and slide it over the gas line and the disconnect fitting. $.40 cents. Simple... I have not had the disconnect problem happen again. My adrenaline level has returned to normal.
Published by: RandyMoon
Model Year: 2005
Share
Related Mods
  • Steering Connector and Drainage Holes
    Motor - - December 1, 2019
    This picture shows the custom-built connector from the steering system to the engine. We started with a connector from the dealer, but it didn't fit right. We had a welder build a new one, and it works great! We leave the engine and rudders both conn...
  • Gas Tanks - Installation & Draining
    Note gas tanks on either side - these were there when I bought the boat. I believe they are 9 gallon tanks. The past owner had do some minor cutting to the openings to get them in. From there, he cut holes in the seat, put those plastic screw plugs i...
  • Yamaha FT60/26M Installation
    Motor - - June 4, 2005
    A few notes about installing the Yamaha FT60 on the 26M. The standard motor controller would not fit inside the pedestal box, and we couldn't find another motor controller to do the job, so it was mounted externally. The control cables were then rout...
