Wheel Steering Conversion
- Boat Type: Boat Type
I never enjoyed docking with two tillers, a shifter, and less than three hands. So a steering wheel conversion seemed like a good solution. Here's what I opted do do:
1) Upgraded my tiller outboard to a different one with remote. Folks who already have remote motors are one step ahead of where I started.
2) Installed a factory pedestal setup from a Macgregor 26M. This was mostly stock stuff from the Macgregor factory, except for a reinforcing plate that was made locally for under the cockpit floor.
3) Added a dual cable rack and pinion steering system -- with one cable to control the motor and the other for the rudders. Again, all off-the-shelf components here -- except for the rudder control arms. I made these from stainless railing supplies to match the rudder movement up with the steering cable.
Seems to work quite well so far, and it provides the linkage between the rudders and motor the M19 sorely missed.
Next up, a helm seat..
Published by: Zavala
Related Mods
Steering Connector and Drainage HolesMotor - - December 1, 2019
This picture shows the custom-built connector from the steering system to the engine. We started with a connector from the dealer, but it didn't fit right. We had a welder build a new one, and it works great! We leave the engine and rudders both conn...
Gas Tanks - Installation & DrainingMotor - - December 1, 2019
Note gas tanks on either side - these were there when I bought the boat. I believe they are 9 gallon tanks. The past owner had do some minor cutting to the openings to get them in. From there, he cut holes in the seat, put those plastic screw plugs i...
Fuel Line Disconnect ProtectorMotor - - July 21, 2005
One of the most aggrevating problems I was having was accidentally disconnecting the gasline connection fitting to the gas tank. I must have happy feet, because everytime I needed to use the motor to get me out-of-trouble, the engine would die becaus...
