Electric Panel and Radio
Published date: September 15, 2005
  • Boat Type: Boat Type
When upgrading to a dual battery setup, I wanted to separate the various circuits on the boat. An inexpensive electical panel was just the ticket.
The panel fits nicely just inside the companionway hatch. Below that I found a good place to install a radio / CD changer controller we took out of our old truck before selling it.
The electrical panel came with a momentary on/off test button for a single battery. I replaced this with a dual pole switch from Radio Shack, so I can check either the House or Starter battery.
Below the voltage meter, I also installed a bridge switch for my dual battery combiner. It's handy to access, and allows me to force the batteries to combine when needed.
Published by: Zavala
Model Year: 2005
Share
Related Mods
  • 12V Plug, Screen
    12V Plug, Screen
    Electrical - - December 1, 2019
    This picture shows a 12V plug that I added just inside the companionway, above the head door. There is a convenient, out of the way place in the corner in the corner of the head for the inside part of the plug. The wiring runs above the head door, th...
  • Rewiring
    Rewiring
    (A) is the power cables coming from the VHF and the compass. (B) is a bus bar that I glued onto the wall in the battery compartment. Wires run from the battery to this, and then to other circuits in the boat. I put a new heavier marine-grade cable fr...
  • Rewiring
    Rewiring
    No wiring other than the VHF power cords (I didn't do it) and a short wire from the fan are exposed in the interior. With patience, everything can be run through the conduits. All along the conduits are plastic hole covers from where the factory need...
