Dual Batteries Under V-Berth
- Boat Type: Boat Type
I installed a dual battery setup in the forward most aceess panel of the V-Berth. It's a very good spot from a weight distribution perspective, especially if you have a heavy motor on the stern to compensate for.
It would be worth the time and money to add a larger, hinged access panel to make the battery removal easier -- but I was short on both. Instead I just worked through the puzzle of getting both batteries positioned into the hole one after another.
Once inside, there really wasn't much room for unintended movement. The bay is too snug for any tilt, so they only needed to be secured side to side. For this, I used some car top carrier straps with eyelets that I screwed into the sides of the panel. Once snugged up, neither battery moves at all.
You also may notice I used a basic West Marine battery combiner, which only bridges the batteries while charging. This gives me peace of mind, and is about as idiot proof of setup as you can find.
Published by: Zavala
Related Mods
12V Plug, ScreenElectrical - - December 1, 2019
This picture shows a 12V plug that I added just inside the companionway, above the head door. There is a convenient, out of the way place in the corner in the corner of the head for the inside part of the plug. The wiring runs above the head door, th...
RewiringElectrical - - December 1, 2019
(A) is the power cables coming from the VHF and the compass. (B) is a bus bar that I glued onto the wall in the battery compartment. Wires run from the battery to this, and then to other circuits in the boat. I put a new heavier marine-grade cable fr...
No wiring other than the VHF power cords (I didn't do it) and a short wire from the fan are exposed in the interior. With patience, everything can be run through the conduits. All along the conduits are plastic hole covers from where the factory need...
