Water tank and pump upgrade
Published date: November 13, 2005
  • Boat Type: Boat Type
Here is on demand faucet/pump with Walmart 5 gallon water jug under area foward of sink. Currently I have a short fill hose that comes up into a basket under the seat. A vent hose runs up to under the sink.
Published by: Mike Ford
Model Year: 2005
Share
Related Mods
  • Bilge pump
    Bilge pump
  • Faucet
    Faucet
  • Water tank and deck fitting
