Electric Balast
Published date: March 7, 2006
  • Boat Type: Boat Type
I have put this mod under 26X but infact I purchased an Odin 820 last year after much deliberation of whether to buy the Odin or 26X. Anyway I am very pleased with the boat which has many simularities with the Mac. I have embodied many of the mods on these pages. However one I had not seen here is the fitting of an electric drain valve to the rear ballast system. I purchased an RV electric waste valve from the US an now with the press of a button I can open and close the rear valve without having to get onto the transom. I will post photos if anyone is interested. Aye cluett-green@bigfoot.com
Published by: MS Classifieds
Model Year: 2006
Share
Related Mods
  • Bilge pump
    Bilge pump
  • Faucet
    Faucet
  • Water tank and deck fitting
