Electric Water Ballast
Published date: March 11, 2006
  • Boat Type: Boat Type
I did not know how to modify my earlier posting so have attached some pictures of the modification showing valve and switch - refer to my earlier posting (651)
Published by: MS Classifieds
Model Year: 2006
Share
Related Mods
  • Bilge pump
    Bilge pump
  • Faucet
    Faucet
  • Water tank and deck fitting
