VHF Antenna
Published date: December 1, 2019
  • Boat Type: Boat Type
The VHF antenna cable (B) passes through the deck near the mast base. When you drill you hole for the cable, you have to watch for two things:
* Make sure that you drill far enough to the side so that you do not hit the metal backing plate (A).
* Make sure you drill far enough fore or aft so that the antenna cable doesn't rub against the centerboard cable. I went aft of the centerboard cable so that it was easier to reach the cable from the inside. Otherwise the support bar gets in the way.
The dark smudges to the left and right on the picture are from the adhesive used to mount the plastic covers that surround the metal support bar. Be careful not to crack the plastic covers when you remove them. I used a piece of metal that I could slide along parallel to the upper liner that cut through the adhesive. This way you don't have to pry the covers off and risk cracking them. After you run the antenna, use adhesive to attach the covers again. You shouldn't have to leave any evidence that anything is even in there.
The antenna cable runs through the ceiling conduits to the side conduit above the galley. This is where is passes from the upper to the lower liner. From here it runs aft and comes out of the wall just in back of the radio where it attaches with a 90deg. elbow? connector.
Also in this picture, between the word "Fore" and the support bar, you
can see the new main battery cable going to the front panel.
Published by: Heath
Model Year: 1997
Share
Related Mods
  • VHF Radio, Hooks
    VHF Radio, Hooks
    Instruments - - December 1, 2019
    (A) shows the VHF radio we had installed. The guy doing the installation ran into the lower-upper liner problem and decided to just run the power lines outside the wall for a short distance from the upper liner and then into the side of the house bat...
  • VHF Antenna
    VHF Antenna
    This shows where the antenna cable exits the deck. It comes out right next to the conterboard cable without rubbing against it. This end connects with the antenna cable exiting the mast on the same side. To get the coaxial antenna cable to come out t...
  • Compass in Cockpit
    Compass in Cockpit
    I have added a compass in the cockpit. The only thing to watch out for is when you are drilling the hole in the bulkhead, make sure that when you insert the compass, it does not hit the sides of the access compartment behind the bulkhead. The line yo...
