ROCNA Anchor Mount
Published date: July 29, 2006
  • Boat Type: Boat Type
Bellaroo's ROCNA anchor is probably one of the best additions to her inventory. Although rather pricey, the security when she's dug-in is worth every penny. Along with the 30' of SS chain, and sweet HD swivel unit, her gear looks as good as it functions.
The stock anchor mount was perfect for a small BRUCE anchor, but the design was tested with less than acceptable results in the soft Florida sand, which is Pensacola Bay.
I removed and replaced the stock roller with a Windline (I believe that was the name) unit, right off the WM shelf. Fortunately, I paid 20% less on sale so it was only modestly over priced, rather than being ridiculously overpriced.
The mounting was reinforced under the deck with a 1/8" aluminum plate after gaining access through the bow triangle in the V berth. Claustrophobia a constant concern, I jammed m 6'self into it and installed the backing plate as large as the area would allow and sealed it with a generous application of 5200. It's not coming off and it's not going to leak. Maybe the deck will separate from the hull, but the anchor roller won't come off.
For security, the red line is cleated to keep that hook there until deployed. Wouldn't want an accidental anchor drag, because the RONCA doesn't drag - it digs. That may be when the deck would come off.
Michael
Published by: mtc
Model Year: 2006
Share
Related Mods
  • Anchor roller
    Anchor roller
    Anchoring - - December 1, 2019
    I mounted the custom anchor roller from Blue Water Yachts on "Sea Breeze." Works great and was not too difficult to install. The bow light is relocated onto a special bracket on the anchor roller. I had to extend (actually I replaced) the wire supply...
  • Quick and easy anchor roller
    Anchoring - - May 24, 2005
    As I was searching the forum for ideas on installing an anchor roller, I came across a post from Norbert describing a very simple and easy "instant" anchor roller, and decided that it would suffice for my purposes. Basically, it consists of a 3" bow ...
  • URM-2 Roller for Bullwaga
    Anchoring - - March 19, 2005
    I added a URM-2 roller to Catigale to make the anchor easy to deploy. We sail on the Hudson a lot and tides are shifty, so it is nice be able to get your anchor out quickly The roller fits nicely between the forestay chain plate and the cleat. The UR...
