X: V-Berth Extension
Published date: August 2, 2006
  • Boat Type: Boat Type
i didn't like the way that the port front seat was lower than the V-Berth or the starboard dinette seat. also, the V-Berth was too short.
1) i raised the port front seat using WM 1/2" marine board. it's an open box that fits in the existing space. about 3" high. has a top for support and allows for additional storeage. fastened in place with a couple of small bolt so can be removed if desired. existing pad sits on top, backrest sits about 3" higher and is fastened with velcro.
2) i modified the existing bilge cover plate located on the port front seat to be used across the two seats which lengthened the V-Berth to a full size bed. incorporated a post, post support, and velcro on each side for support and strength.
3) purchased a small foam pad to occupy the new V-Berth space.
starboard front seatback is placed under dinette or in rear while V-Berth is in the full size bed position.
Published by: Bobby T.-26X #4767
Model Year: 2006
Share
Related Mods
  • V-Berth Aft Extension
    Berths - - May 26, 2006
    Problem: The Mac V-berth is a bit short for tall folks. Solution: The OEM removable forward seatback for the dining table was modified to serve the additional purpose of extending the port side of the berth to match the forward dinette seat bottom. E...
  • Convert Cockpit to Berth
    Berths - - March 20, 2006
    Problem: The Mac cabin can get a bit warm mid-summer nights, and I am accustomed to cool mountain evenings. Others may find this cockpit berth more accessible than the aft berth, more comfortable than the table berth, or just a fun alternative. Solut...
  • Aft Berth High-Density Foam Tiles
    Berths - - May 8, 2005
    To protect the berth deck when we have the mattresses out and are using the area for storage, we installed some of these 1/2" thick high-density foam interlocking tiles. Their surface has a non-skid embossed pattern to help prevent gear sliding. We c...
