lifeline
Published date: October 4, 2006
  • Boat Type: Boat Type
Ever reach for the lifeline for support when your X is heeling and grab the lifeline bracket and its frayed wires? OUCH! Solution> Unscrew pelican from front end of lifeline and slide a rubber shrinkwrap on and cover that annoying bracket. Dresses up the fitting and protects hands.
Published by: rick retiree
Model Year: 2006
Share
Related Mods
  • Quick Release Pins
    Quick Release Pins
    Rigging - - December 1, 2019
    We all hate to mess with clevis pins right? Try ball lock pins. I use 1/4 " x 2" pins on the boom/mast gooseneck connection, the tack of the main, and to fasten the roller reefing drum to the bow. Never had one come loose but I recommned using long p...
  • Rigid Vang
    Rigid Vang
    Rigging - - July 29, 2006
    I recently installed this Garhauer rigid vang set-up. Well made, easy to rig, and does a great job keeping the boom just where I want it. Jibes are safer, trimming more precise, and it eliminates the need for a topping lift when the main's down. The ...
  • Rudder Lines
    Rudder Lines
    I'm all for a good work out, but control lines on my sailboat should be easy enough that I don't need to do my Arnold imitation every time I pull a line. The 1:1 stock rudder lines, illustrated on the lower image (along with my Belle, Bellaroo's name...
