Bolts Without Wrenches
Published date: November 5, 2006
  • Boat Type: Boat Type
Here is a simple way to NOT carry wrenches when you are setting up your boat. I've welded 1/4" x 2" stainless steel bolts to the head of the 3/8th bolts that are used on the mast. The self-locking nut was drilled and tapped with a 10/32 tap. Don't over cut the threads and put the 10/32 bolt in with locktight. This trick can also be applied to the 1/4" bolts. There you need a stailess steel nail and a smaller screw in the nut.
Published by: ericorville
Model Year: 2006
Share
Related Mods
  • Quick Release Pins
    Quick Release Pins
    Rigging - - December 1, 2019
    We all hate to mess with clevis pins right? Try ball lock pins. I use 1/4 " x 2" pins on the boom/mast gooseneck connection, the tack of the main, and to fasten the roller reefing drum to the bow. Never had one come loose but I recommned using long p...
  • lifeline
    lifeline
    Rigging - - October 4, 2006
    Ever reach for the lifeline for support when your X is heeling and grab the lifeline bracket and its frayed wires? OUCH! Solution> Unscrew pelican from front end of lifeline and slide a rubber shrinkwrap on and cover that annoying bracket. Dresses up...
  • Rigid Vang
    Rigid Vang
    Rigging - - July 29, 2006
    I recently installed this Garhauer rigid vang set-up. Well made, easy to rig, and does a great job keeping the boom just where I want it. Jibes are safer, trimming more precise, and it eliminates the need for a topping lift when the main's down. The ...
