cutter rig
Published date: December 19, 2006
  • Boat Type: Boat Type
Have been getting lots of requests for this so I guess it's about time . I've coverted my mac19 to a cutter rig which I designed myself with a 4ft bowsprit with an extended bow pulpit & cat walk with step seat 2 cdi furlers second set of spreaders and a third set of middle stays which allows me to fly 3 head sails all together jib staysail genny, spin with my main approx 650sq ft of sail, cabin top jib,genoa track extra jib winches look closely at the pic's. New 26m pedestal wheel steering with the lots of help from Zavala "kevin" bimini top on 4ft genoa track
Published by: MS Classifieds
Model Year: 2006
Share
Related Mods
  • Quick Release Pins
    Quick Release Pins
    Rigging - - December 1, 2019
    We all hate to mess with clevis pins right? Try ball lock pins. I use 1/4 " x 2" pins on the boom/mast gooseneck connection, the tack of the main, and to fasten the roller reefing drum to the bow. Never had one come loose but I recommned using long p...
  • Bolts Without Wrenches
    Rigging - - November 5, 2006
    Here is a simple way to NOT carry wrenches when you are setting up your boat. I've welded 1/4" x 2" stainless steel bolts to the head of the 3/8th bolts that are used on the mast. The self-locking nut was drilled and tapped with a 10/32 tap. Don't ov...
  • lifeline
    lifeline
    Rigging - - October 4, 2006
    Ever reach for the lifeline for support when your X is heeling and grab the lifeline bracket and its frayed wires? OUCH! Solution> Unscrew pelican from front end of lifeline and slide a rubber shrinkwrap on and cover that annoying bracket. Dresses up...
