Anchor Light
Published date: April 2, 2007
  • Boat Type: Boat Type
I wanted an LED anchor light. I had one installed on the Mast Support. This works well and lights up the cockpit for boarding at night. I do need to lift the boom high so the light can be seen better at night.
Published by: James V
Model Year: 2007
Share
Related Mods
  • Anchor Light and Windvane
    Lighting - - December 1, 2019
  • Light In Head
    Light In Head
  • Light in the headroom
