Table Light
Published date: April 2, 2007
  • Boat Type: Boat Type
I had a double neon light put in above the table. This is bright enough to read fine print at night. Should have done this first as it makes the cabin much more usable at night.
Published by: James V
Model Year: 2007
Share
Related Mods
  • Anchor Light and Windvane
    Lighting - - December 1, 2019
  • Light In Head
    Light In Head
  • Light in the headroom
