VHF Antenna
Published date: December 1, 2019
  • Boat Type: Boat Type
This shows where the antenna cable exits the deck. It comes out right next to the conterboard cable without rubbing against it. This end connects with the antenna cable exiting the mast on the same side.
To get the coaxial antenna cable to come out through the mast, pick a spot on the side that is near enough to the bottom that you can easily reach your hand or arm up the bottom of the mast to push the cable out through the hole. Then find a rubber grommet with the right interior diameter to match the cable. Drill a hole the same diameter as the groove in the grommet, and push it into place. Then you can push the coax. through it.
To find the location for drilling through the deck, first go below and locate the position relative to the various bolts in and around the mast base. Find the same location on the deck, recheck the position so that it won't hit the centerboard cable, hold your breath, and drill.
The best thing that I found for running wiring up the mast is a "sewer snake". This is a stiff wire that you can tape things to and push them through the length of the mast.
Published by: Heath
Model Year: 1997
Share
Related Mods
  • VHF Radio, Hooks
    VHF Radio, Hooks
    Instruments - - December 1, 2019
    (A) shows the VHF radio we had installed. The guy doing the installation ran into the lower-upper liner problem and decided to just run the power lines outside the wall for a short distance from the upper liner and then into the side of the house bat...
  • VHF Antenna
    VHF Antenna
    The VHF antenna cable (B) passes through the deck near the mast base. When you drill you hole for the cable, you have to watch for two things: * Make sure that you drill far enough to the side so that you do not hit the metal backing plate (A). * Mak...
  • Compass in Cockpit
    Compass in Cockpit
    I have added a compass in the cockpit. The only thing to watch out for is when you are drilling the hole in the bulkhead, make sure that when you insert the compass, it does not hit the sides of the access compartment behind the bulkhead. The line yo...
