galley, head new faucet and cockpit shower,12 volt pump.
Published date: May 9, 2007
  • Boat Type: Boat Type
12 volt water pump close to the water tank. a new faucet in the galley and a faucet-shower in the head. 4 mt long hose and you can have your shower in the cockpit.
Published by: marsanden
Model Year: 2007
Share
Related Mods
  • Bilge pump
    Bilge pump
  • Faucet
    Faucet
  • Water tank and deck fitting
