Custom built bow roller
Published date: June 16, 2007
  • Boat Type: Boat Type
After dragging the anchor several times decided we needed a better one but the dinky standard bow roller was not up to it.
I fabricated the setup in the photo and installed as big a plate under the deck as I could fit. Just to make sure installed another strut to the existing bolt holding the headstay bracket as there is a fair bit of overhang.
The no3 SARCA is a bit oversize for a Mac but I can now sleep without worry.
By drilling a hole in the shaft of the sand anchor it also fits and is still used in river situations where losing it is not a problem.
Published by: MS Classifieds
Model Year: 2007
Share
Related Mods
  • Anchor roller
    Anchor roller
    Anchoring - - December 1, 2019
    I mounted the custom anchor roller from Blue Water Yachts on "Sea Breeze." Works great and was not too difficult to install. The bow light is relocated onto a special bracket on the anchor roller. I had to extend (actually I replaced) the wire supply...
  • U-bolt for Anchor Line
    Anchoring - - April 2, 2007
    I had a U-bolt installed for the other end of the anchor line. Not hard, Just take out the carpet at the end of the V-berth and remove the foam. This will hold the end of the anchor line if it gets loose. Published by: James V
  • Anchor rode hatches
    Anchor rode hatches
    Anchoring - - December 19, 2006
    Here's my fore deck anchor rode hatches they have rubbermaid containers attached to the inside of them so any wet rode does not get into the cabin the foam floatation that I removed was then reinstalled in the v-berth area Published by: MS Classified...
