Fender /rope holders
Published date: June 16, 2007
  • Boat Type: Boat Type
Wanted four fender holders but now reckon I need two more, at $70+ a pop decided to make my own but incorporated a rope/? holder on it as well, This has worked really well for keeping mooring ropes tidy.
The only problem is they stick out a bit and along with the barbeque fouled the walls of the locks, if we weren't watching.
Published by: MS Classifieds
Model Year: 2007
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Dingy & Kayak Anchor System
    Miscellaneous - - March 16, 2007
    Problem: While snorkeling, diving, swimming etc., it is good to know that your transportation stays around, e.g. your dingy or kayaks. Commercial packaged systems commonly have poor quality components or unsuitable sizing of anchors, ropes, and float...
