eng. pro-highjacker 10" set back plate
Published date: June 25, 2007
  • Boat Type: Boat Type
Installed my eng. 10" set back plate this should increase my top end speed & save on fuel it also gets the eng. out of the eng. well allowing me to install a drop leaf eng.well floor increasing my cockpit floor area
[IMG]http://i78.photobucket.com/albums/j95/maccutter19/Winged%20Centerboard/new%20ruuders%20highjacker%20plate/I3010005.jpg[/IMG]
[IMG]http://i78.photobucket.com/albums/j95/maccutter19/Winged%20Centerboard/new%20ruuders%20highjacker%20plate/I3010004.jpg[/IMG]
Cheers John
Published by: Highlander
Model Year: 2007
Share
Related Mods
  • Steering Connector and Drainage Holes
    Motor - - December 1, 2019
    This picture shows the custom-built connector from the steering system to the engine. We started with a connector from the dealer, but it didn't fit right. We had a welder build a new one, and it works great! We leave the engine and rudders both conn...
  • Gas Tanks - Installation & Draining
    Note gas tanks on either side - these were there when I bought the boat. I believe they are 9 gallon tanks. The past owner had do some minor cutting to the openings to get them in. From there, he cut holes in the seat, put those plastic screw plugs i...
  • Motor flush system
    Motor flush system
    Motor - - May 30, 2007
    As our boat is kept on a swing mooring for the season and our Yamaha 50 4/stroke has an external engine flushing connection I thought that flushing the engine after salt water use was a good idea, so using the aft shower I adapted garden hose quick d...
