Pressure water system part 2
Published date: June 26, 2007
  • Boat Type: Boat Type
Water lines
The water lines are Rehau domestic house plumbing plastic lines bonded to the hull to stop line hammer. Water supply to the pump is via a rubber flexible line.
Fittings
The tap is a standard household flick mixer with the hot water inlet blocked off. The deck mounted water tank filler fitting is located on the aft starboard side and is connected to the holding tank by a 1 1/2 inch fill line
Jack Sparrow
Published by: Jack Sparrow
Model Year: 2007
Share
Related Mods
  • Bilge pump
    Bilge pump
  • Faucet
    Faucet
  • Water tank and deck fitting
