mac19 bilge pumps
Published date: July 1, 2007
  • Boat Type: Boat Type
I installed 2 automatic bilge pumps in the rear of the aft birth one on each side of the water ballast tank I glued 1/2" plastic blocks on each 2 per side should have used 1 per side bigger blocks, I attached the bilge pumps & float switches to an alum L shaped brkt that I made,I then screwed them onto the plastic blocks with 3/8" ss screws the outlet hoses go up through the rear of the transom to outlets one on each side, the auto/manual bilge pump switches are mounted on the pedestal half way up one on each side port switch opperates the port pump s/b switch opper. the s/b pump
John
Published by: Highlander
Model Year: 2007
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Fender /rope holders
    Miscellaneous - - June 16, 2007
    Wanted four fender holders but now reckon I need two more, at $70+ a pop decided to make my own but incorporated a rope/? holder on it as well, This has worked really well for keeping mooring ropes tidy. The only problem is they stick out a bit and a...
