bilge blower
Published date: July 1, 2007
  • Boat Type: Boat Type
I installed a bilge blower fan in the S/B section of the transom between the transom & liner at the rear aft birth I installed two nicro snap in 4" deck plates in both rear corners of the cockpit I then cut out the lid centers to incorperate the black vents which I glued fiber sceening to the insides to keep the bugs out I then cut out enough styrofoam to allow me to install the 3" flexable vent hose, I replaced the styrofoam with new 4"x5" blocks I was able to put back twice as much as I took out re cutting new styrofoam blocks 4"x 5" .The S/B vent is the outlet its hose goes down to the bilge blower in the S/B transom location then a short hose from there to the aft blige directly below, the port vent is the inlet it goes down the aft port corner of the transom then under & through the port side aft birth floor outer section underneath comes up through under the port side dinning seat towards the bow so venting from the bow back to the transom
Cheers John
Published by: Highlander
Model Year: 2007
Share
Related Mods
  • Hatch Adjuster
    Hatch Adjuster
    Ventilation - - December 1, 2019
    The front hatch did not come with a hatch adjuster so there was no easy way to keep the front hatch open except for letting it flop all the back against the deck. This put a lot of stress on the hinges plus it was pretty unattractive. I installed a h...
  • Hatch Lift
    Hatch Lift
    We installed a gas lift (the same type as used in hatchback cars) to keep the hatch partially open. The lift was available at West Marine, as were the brackets. I would recommend the 40# lift, as anything less seemed to hold the hatch open, but just ...
  • vents
    vents
    I have a MacGregor 19. (It's for sale by the way). I installed three vents that have totally eliminated any venting or ordor problems. I first installed a stainless steel louvered vent in the head door. I then installed a cowl vent in the head just t...
