Bollard
Published date: July 1, 2007
  • Boat Type: Boat Type
As we moor our boat for the season a substantial rode attachment was required. We removed the factory cleat and installed a bollard with a large backing plate to spread the load then sealed it with waterproof sealant
Jack Sparrow
Published by: Jack Sparrow
Model Year: 2007
Share
Related Mods
  • Anchor roller
    Anchor roller
    Anchoring - - December 1, 2019
    I mounted the custom anchor roller from Blue Water Yachts on "Sea Breeze." Works great and was not too difficult to install. The bow light is relocated onto a special bracket on the anchor roller. I had to extend (actually I replaced) the wire supply...
  • Custom built bow roller
    Anchoring - - June 16, 2007
    After dragging the anchor several times decided we needed a better one but the dinky standard bow roller was not up to it. I fabricated the setup in the photo and installed as big a plate under the deck as I could fit. Just to make sure installed ano...
  • U-bolt for Anchor Line
    Anchoring - - April 2, 2007
    I had a U-bolt installed for the other end of the anchor line. Not hard, Just take out the carpet at the end of the V-berth and remove the foam. This will hold the end of the anchor line if it gets loose. Published by: James V
