10" eng. set back plate/wedge kit
Published date: July 2, 2007
  • Boat Type: Boat Type
I have installed a 10" pro high-jacker set back plate this moves the eng out of the eng. well and allowed me to install a drop leaf floor to the rear of my cockpit covering up the eng. well so I can now stand behind my pedestal "helsman seat still in the making" the set back is a heavy duty one 1/2" alum. ment for a V-6 outboard eng but it was what I had to go with to get the 10" set back I needed it is also adj. which allowed me to set my eng. cavitaion plate even with the bottom of my transom I have to install the 10" trim plate I bought that fits on the bottom of the set back this along with the wedge kit will give me more top end speed cruise on plane with lower RPM's will save gas it will give me the equal benifit of adding ten more HP without buying a bigger eng. it also increases the hull length under power which is good. The set back weight is 45# with that & moving the eng. back it should give me the extra ballast where I will need it when flying 2 or 3 head sails at once .
Cheers John
Published by: Highlander
Model Year: 2007
Share
Related Mods
  • Steering Connector and Drainage Holes
    Motor - - December 1, 2019
    This picture shows the custom-built connector from the steering system to the engine. We started with a connector from the dealer, but it didn't fit right. We had a welder build a new one, and it works great! We leave the engine and rudders both conn...
  • Gas Tanks - Installation & Draining
    Note gas tanks on either side - these were there when I bought the boat. I believe they are 9 gallon tanks. The past owner had do some minor cutting to the openings to get them in. From there, he cut holes in the seat, put those plastic screw plugs i...
  • eng. pro-highjacker 10" set back plate
    Motor - - June 25, 2007
    Installed my eng. 10" set back plate this should increase my top end speed & save on fuel it also gets the eng. out of the eng. well allowing me to install a drop leaf eng.well floor increasing my cockpit floor area [IMG]http://i78.photobucket.com/al...
