custom made lockable fuse box
Published date: July 2, 2007
  • Boat Type: Boat Type
I purchased an RV external hydro electrical outlet box & coverted it into a lockable fuse box I basicaly installed a 4 gang fuse holder & ground block inside and wired up it feeds extra 12 volt power to my pedestal , cabin flourecent light and all cabin l,e,d lights, the fourth fuse is still to be connected yet I have ordered a second one to install in the cockpit poss in the pedestal. In the third pic you can see the white abs plastic pipe I heated and then formed to go around the eng, well from the bottom of the pedestal to the rear of the transom S/B side to the electrical junction boxes with the covers removed I then cut a 1/4" slot all the way along the back of the abs pipe this allows me to remove or add extra wiring at ease, drilled 2 small holes in the liner at each attachment point fed through plastic tie raps they hold the pipe up firmly the slot is hidden in the back of the pipe
Cheers John
Published by: Highlander
Model Year: 2007
Share
Related Mods
  • 12V Plug, Screen
    12V Plug, Screen
    Electrical - - December 1, 2019
    This picture shows a 12V plug that I added just inside the companionway, above the head door. There is a convenient, out of the way place in the corner in the corner of the head for the inside part of the plug. The wiring runs above the head door, th...
  • Rewiring
    Rewiring
    (A) is the power cables coming from the VHF and the compass. (B) is a bus bar that I glued onto the wall in the battery compartment. Wires run from the battery to this, and then to other circuits in the boat. I put a new heavier marine-grade cable fr...
  • Rewiring
    Rewiring
    No wiring other than the VHF power cords (I didn't do it) and a short wire from the fan are exposed in the interior. With patience, everything can be run through the conduits. All along the conduits are plastic hole covers from where the factory need...
