Reading light
Published date: July 3, 2007
  • Boat Type: Boat Type
As we fitted a bulkhead across the rear berth lighting then became an issue. A spot reading light is installed just inside the aft berth entry.
Jack Sparrow
Published by: Jack Sparrow
Model Year: 2007
Share
Related Mods
  • Anchor Light and Windvane
    Lighting - - December 1, 2019
  • Light In Head
    Light In Head
  • Light in the headroom
