Rewiring
- Boat Type: Boat Type
(A) is the power cables coming from the VHF and the compass.
(B) is a bus bar that I glued onto the wall in the battery compartment. Wires run from the battery to this, and then to other circuits in the boat. I put a new heavier marine-grade cable from here to another bus bar for power distribution controlled by the front (original) circuit panel. The front panel is used to control the running/steaming/anchoring lights and the interior lights.
(C) is an additional circuit panel that we had installed to control other future circuits. Right now we have the only the compass light running through it. It also has a 12V outlet and a battery meter. The battery meter isn't that useful though. If I did it again, I would instead install a circuit panel with more switches.
Published by: Heath
Related Mods
3D Printed West Marine Panel odElectrical - (MacGregor 26X) - August 7, 2020
I have three West Marine power panels in my 26x right now. I had only one small 4-switch one initially, but my system and needs have grown with my recent revising of the electrical system. I have an issue with these simple and inexpensive panels. Old...
Shore Power 120v AC panel 26MElectrical - Shore power (MacGregor 26M) - May 21, 2020
Marinco Stainless inlet, Blue Sea Systems AC Panel 8101 and outlets on a 2007 26M The key to successful inlet placement when you have to cut the Large hole in the boat was to cut the panel hole first, remove all foam, make a template of the inlet siz...
Electrical outlet near the dinetteElectrical - (MacGregor 26X) - December 1, 2019
A power outlet in the corner headroom/aft dinett seat/hull for mobile phone and everything else you might use while sitting by the dinett. Published by: MS Classifieds
