Gooseneck mod
Published date: July 14, 2007
  • Boat Type: Boat Type
While having a pleasant day sailing I dropped the sail to head for home not only did I drop the sail I dropped the boom on the head of the Admiral. During the subsequent investigation we discovered the gooseneck had parted company of the boom (broken the casting where the 1/4 bolt passes through the gooseneck). The repair was quite simple 4x10/32 stainless steel fine threaded metal screw drilled and taped 45 degrees apart loctited in and a bunch of flowers
Jack Sparrow
Published by: Jack Sparrow
Model Year: 2007
Share
Related Mods
  • Quick Release Pins
    Quick Release Pins
    Rigging - - December 1, 2019
    We all hate to mess with clevis pins right? Try ball lock pins. I use 1/4 " x 2" pins on the boom/mast gooseneck connection, the tack of the main, and to fasten the roller reefing drum to the bow. Never had one come loose but I recommned using long p...
  • Rigging up grade
    Rigging up grade
    Rigging - - July 4, 2007
    After struggling for a season trying to keep the shroud tensions right, maintaining the correct mast bend and rake angle and also keeping some sort of tension on the forestay, I decided to scrap the whole rigging and start again. One of the annoyance...
  • Furler cleat
    Furler cleat
    Rigging - - June 22, 2007
    We replaced the furler cleat with a spinlock rope jammer. Pop out the deck head covers under the cleat and the undo the bolts and remove the cleat. Only one of the spinlock holes will line up with the original holes fill the unused hole up with water...
