Additional new section
Published date: July 20, 2007
  • Boat Type: Boat Type
I believe many Mac owner are frustrated with Mac's slow speed. so some of the owners must have up-graded on improving speed with additional battery operating mtor as a auxiliary power while sailing.
I would like to know more about their improving on sailing speed. Please add this "speed" section.
Thank you
Published by: MS Classifieds
Model Year: 2007
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • mac19 bilge pumps
    mac19 bilge pumps
    Miscellaneous - - July 1, 2007
    I installed 2 automatic bilge pumps in the rear of the aft birth one on each side of the water ballast tank I glued 1/2" plastic blocks on each 2 per side should have used 1 per side bigger blocks, I attached the bilge pumps & float switches to an al...
