Garhauer rigid boom vang
- Boat Type: Boat Type
Installed my Garhauer rigid boom vang , cut two pieces of 1/4 alum flat bar 1" wide for mast & 5/8" wide for boom same length as track clamped together drilled out the seven mounting holes in the alum flat bar 3/6" tapped them out to 1/4' coarse thread one at a time then installed each mounting screw one at a time this made shure all holes would match up perfectly nothing to get out of align. installed track on mast with straps approx 2" up from the bottom drilled out mast mounting holes 1/4" removed track redrilled holes in mast out to 5/16" slid alum flat bar into mast installed one screw to hold bar in possition used blue loctite installed one screw into track and into other end of bar remove other holding screw install all seven screws with blue locktite you may have to use a small screw driver to line up holes , followed instructions for mounting boom track drilling out the middle 2 holes only in the boom, when satisfied with possition marked boom drilled out all holes 1/4" removed track redrilled all holes in boom out to 5/16" removed boom end brkt & bale slid alum bar down into boom poss. had to play with it to get it align. made shure it did not flip over on me otherwise holes may not line up ? again install one screw in end to hold in place then procced to intall track from other end
Cheers John
Published by: Highlander
Related Mods
Quick Release PinsRigging - - December 1, 2019
We all hate to mess with clevis pins right? Try ball lock pins. I use 1/4 " x 2" pins on the boom/mast gooseneck connection, the tack of the main, and to fasten the roller reefing drum to the bow. Never had one come loose but I recommned using long p...
assy spinnakerRigging - - July 16, 2007
This is my setup for flying an assymetric spinnaker. first of all the tack line is attached to the pulpit rail by a swivel block. A bolt is installed on the bracket that holds the mast base when the mast is in transport mode and this secures the top ...
Gooseneck modRigging - - July 14, 2007
While having a pleasant day sailing I dropped the sail to head for home not only did I drop the sail I dropped the boom on the head of the Admiral. During the subsequent investigation we discovered the gooseneck had parted company of the boom (broken...
