Dock Whip
Published date: July 25, 2007
  • Boat Type: Boat Type
Where my 26M is docked there's only three mooring points. I got tired of having the starboard stern constantly bumping and rubbing the floating dock. Dock whips can be purchased for lots of money, so I invented my own. It's ugly but it works. 1 1/2" pvc flexible pipe, fittings, rigid pipe, flanges and about 5 ' of 3/4" pipe. Double bungee cords do all the work. The flexible pvc allows fore & aft movement.
Published by: JohnMackHi
Model Year: 2007
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Additional new section
    Miscellaneous - - July 20, 2007
    I believe many Mac owner are frustrated with Mac's slow speed. so some of the owners must have up-graded on improving speed with additional battery operating mtor as a auxiliary power while sailing. I would like to know more about their improving on ...
