Helmsmans Seat
Published date: August 15, 2007
  • Boat Type: Boat Type
Another way of a popular modification to the Helmsmans seat without losing the aesthetics.
Cut seat using a thin cutting blade on a 4" angle grinder, (easier than it looks) I actually did mine in situ. I then drilled and rivetted a piano hinge,painted it white and violla, when its in the down position you can't even tell it's been modified
Published by: MS Classifieds
Model Year: 2007
Share
  • This site is not responsible for damage done to your boat.
  • When in doubt, consult a professional. Always comply with local and marine codes.
  • Dont drill holes in the bottom of your boat.
  • Happy sailing
Related listings
  • Cockpit Queen size bed
    Cockpit - - December 1, 2019
    Its usually too warm around Corpus Christi to sleep inside our cabin when we travel and anchor somewhere to sleep. The solution is simple. Mount six one inch strips of wood 6- ten inches long, which have had one edge rounded, to 3/4 of an inch below ...
  • Autohelm (Sort - of)
    Here's a real HIGH TECH autohelm.... Sometimes I am sailing alone, have the boat going straight & even, & want to go down below for a few minutes (or maybe just for a beer). I have put one of the little eye-straps below the steering wheel, and I run ...
  • Winch Handle Pocket
    Winch Handle Pocket
    See the attached where we placed a winch handle pocket. It is easy to find, and the pocket is always right where you need it (near the winches). Also note one of the doors that were constructed with the vent in the door. These are made of tinted plex...
