26X Jib Boom
Published date: September 24, 2007
  • Boat Type: Boat Type
My latest mod. to my jib boom includes:
Moved the furler connection point out to the end of the anchor roller.
Added a Bobstay with turnbuckle from beneath the anchor roller down to bow padeye for strength.
Instaled a stainless riser that the boom attaches to.
New preventer which controls the height the boom is allowed to rise, and therefore maintains sail shape.
Stainless traveller connects port and s'board stanchions.
The boom is self tacking,with the s'brd. jib sheet now controlling how far the boom can swing out from boat centerline. The port jib sheet controls how much jib sheet is pulled out from the furler.
Awesome control when wing on winging, as well as reaching, as well asimproving sail shape going upwind.
Published by: MS Classifieds
Model Year: 2007
Share
Related Mods
  • Quick Release Pins
    Quick Release Pins
    Rigging - - December 1, 2019
    We all hate to mess with clevis pins right? Try ball lock pins. I use 1/4 " x 2" pins on the boom/mast gooseneck connection, the tack of the main, and to fasten the roller reefing drum to the bow. Never had one come loose but I recommned using long p...
  • Dagger board block
    Dagger board block
    Rigging - - September 19, 2007
    We got this one from this web site. Rising the dagger board was a quite a task and as my arms are no match for the Governators something had to be done. I used the block off the mast raising system and replace it with an old block I had laying around...
  • Main halyard aft - Harken 140 pivot block w/cam cleat
    Rigging - - August 27, 2007
    Like many, I wanted a setup that leads the main halyard back to the cockpit without inhibiting mast rotation. My dealer-installed system led the halyard through a pulley at the mast base and a turning block to a rope clutch mounted in front of the st...
