Three sectional mast
- Boat Type: Boat Type
Ned Miller asked me awhile back for this so I hope it helps I extended my mast from a two section 23'10" mast to a three section 28' mast the rig now has 36" bottom, 24" middle spreaders 14" jumper struts . 5 sets of shroulds , 4 forestays can fly 4 head sails with 12 differnt combinations this rigg is as solid as it can get great for heavy weather sailing, will be adding a second set of chain plates & poss. a second back stay this winter now that I have it all tweak out!!. on the go right now is a traveler mounted on a rear arch !
Cheers John
Published by: Highlander
Related Mods
Quick Release PinsRigging - - December 1, 2019
We all hate to mess with clevis pins right? Try ball lock pins. I use 1/4 " x 2" pins on the boom/mast gooseneck connection, the tack of the main, and to fasten the roller reefing drum to the bow. Never had one come loose but I recommned using long p...
GooseneckRigging - - October 8, 2007
It wasn't long before the gooseneck attachment rivets worked loose, the forward rivets were removed and the holes enlarged and a thread cut in the mast then stainless steel machine head screws were fitted and Loctited in position Jack Sparrow Publish...
26X Jib BoomRigging - - September 24, 2007
My latest mod. to my jib boom includes: Moved the furler connection point out to the end of the anchor roller. Added a Bobstay with turnbuckle from beneath the anchor roller down to bow padeye for strength. Instaled a stainless riser that the boom at...
