Mast Raising Pole as Furler Support when Trailering
Published date: October 18, 2007
  • Boat Type: Boat Type
When looking at the mast raising pole recently,
it occurred to me that by adding a few eye bolts,
I could make it do double duty as a very nice
support pole for the roller furler when trailering.
I put an 8" 5/16 eye bolt at the end which mounts
to the mast bracket, replacing the original bolt,
and then added two 4" 5/16 eye bolts which line
up with the mast bolt and boom mount (see photos).
The eye bolts stick out to the side when using
the pole for raising/lowering the mast, and are
completely out of the way.
(as an aside, I really love how clean the mast
and stays/shrouds can be packaged up by disconnecting
the stays/shrouds at the base and removing the
spreaders -- well worth the extra setup/take down
time)
Published by: PatrickS
Model Year: 2007
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • 26X CB to daggerboard conversion
    Miscellaneous - - September 3, 2007
    Here are a few pictures of my CB modification. Details are in the Modification Forum under Swing Keel mod (Skeg maybe?) on page 4 Published by: Gerald Gordon
