Mast floatation
Published date: October 21, 2007
  • Boat Type: Boat Type
Well when I rebuilt my mast from a 2 section 24ft to a 3 section 28ft I bought 6X5ft swimming pool noodles & inserted them into the mast they have a 3/4" center hole which allows for installing wires. I figure if I should ever knock down or turtle ! the less weight I have to upright the better I capped the mast head by cutting a piece of plastic out of a cottage cheese container lid !. you can see the noodles in the base of the mast, the 2ft section I had left over
Published by: Highlander
Model Year: 2007
Share
Related Mods
  • Quick Release Pins
    Quick Release Pins
    Rigging - - December 1, 2019
    We all hate to mess with clevis pins right? Try ball lock pins. I use 1/4 " x 2" pins on the boom/mast gooseneck connection, the tack of the main, and to fasten the roller reefing drum to the bow. Never had one come loose but I recommned using long p...
  • Gooseneck
    Gooseneck
    Rigging - - October 8, 2007
    It wasn't long before the gooseneck attachment rivets worked loose, the forward rivets were removed and the holes enlarged and a thread cut in the mast then stainless steel machine head screws were fitted and Loctited in position Jack Sparrow Publish...
  • Three sectional  mast
    Ned Miller asked me awhile back for this so I hope it helps I extended my mast from a two section 23'10" mast to a three section 28' mast the rig now has 36" bottom, 24" middle spreaders 14" jumper struts . 5 sets of shroulds , 4 forestays can fly 4 ...
