Handrail
Published date: November 25, 2007
  • Boat Type: Boat Type
Handrail it is easier to get in the boat from the water using the ladder.
Published by: tico
Model Year: 2007
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Mast Raising Pole as Furler Support when Trailering
    Miscellaneous - - October 18, 2007
    When looking at the mast raising pole recently, it occurred to me that by adding a few eye bolts, I could make it do double duty as a very nice support pole for the roller furler when trailering. I put an 8" 5/16 eye bolt at the end which mounts to t...
