another Auto-Vent
Published date: December 13, 2007
  • Boat Type: Boat Type
Here is another version of ballast tank vent for the 26X late model with vent under the vee berth. I couldn't find the Ace hardware type featured previously on this site but found a "flapper" valve in PVC plastic at a local farmer's supply that looked promising. I thought a ping-pong ball might be enough to raise the valve up, but it kept getting jammed in the chamber so I glued a cylindrical block of floatation foam to the bottom of the valve with WM marine silicone and then was able to pop in the ball to help lift the valve and obtain a tight seal. Used a cable tie to retain the ball from falling into the tank. Then I cut a flange from cutting board and glued it on with silicone as well. I chose the 2" version of valve to get maximum air flow, but a smaller valve would probably work just fine and be a better fit for a ping pong ball. Now I have to wait for spring to try it out!
Published by: Dave Mason
Model Year: 2007
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Handrail
    Handrail
    Miscellaneous - - November 25, 2007
    Handrail it is easier to get in the boat from the water using the ladder. Published by: tico
