This is in the UK, the boat is a 97 model, asking price £12.5k which is very reasonable for over here (most Xs go for a lot more, and the M new is around £20k base price excluding engine etc.).
1. Engine is a Suzuki 55 2-stroke. I'm not so keen on 2-strokes, but any comments on this engine? I think it's the original (need to confirm), the clock shows only 196 hrs. which suggests to me the boat hasn't been heavily used. Due to the way the boat's parked it wasn't possible to run the engine up at the time.
2. There is a lot of water in the bilges, probably 2-3 in. at the centre line. I'm told the boat's hardly been used this year so I guess it's rain water. I know the shround anchor points can leak, so are prime suspect, and are also easily sealed. Are there any other weak points where the rain can get in? I didn't see any evidence of leaks around the windows.
Those are the two main things I'm concerned about. Otherwise the boat's in good condition, and with a lot of gear and equipment thrown in. It even has a stern arch with lines to lift a tender (hmm....) and wind generator! An adjustable backstay's been fitted; there's only the two basic sails, but the main has 3-point single-line reefing. Twin-axle galvanised trailer as well.
I noticed the ballast tank seems to be an interim arrangement, must have been when they started tweaking it. The vent is still in the step, but there's no hull valve, and the transom valve is the big-bore one used on the later boats.
I think I'm going to make an offer for it, but I'd like to know if I might be buying myself a big problem - aargghh!
TIA
Rick
