I think I'm about ready for my first set of mods. I plan to add a two line reefing system, a "down haul" for the main, and run all those lines (4) aft.
I was hoping to post links to the hardware I was planning to use, but even though I seem to meet at requirements now I still cannot post links
As this is my first time, I'd really appreciate if anyone can verify what I am planning is a good way to go and if all of the equipment seems up to the job
What I'm planning is actually very similar to the pictures I've seen via pictures posted by RandyMoon on a thread titled "Main Halyard to Cockpit on 26M" with two exceptions:
1) I will have two single blocks (instead of one) mounted to both the port & starboard base of the mast (4 blocks total). Two for reefing and two for main halyard & downhaul. I was originally planning to just use two double blocks instead of 4 singles but was thinking having a line led up the mast for the main and a line lead more toward the boom for reefing would have a double block trying to be pulled in two separate directions (does that make sense or would two doubles work you think?). The blocks I'm planning to use for all for of these are: "Harken 29 mm Carbo Single / Fixed" (HAR348).
2) Instead of turning the lines aft with deck mounted cheek blocks, I'm thinking I'll turn them aft via a double bullets mounted toward the base of the stanchion on each side. The blocks I'm planning to use for this are: "Harken Bullet Double" (HAR084).
OK, so that is the basic idea I have for getting the lines aft. Just a couple more questions
Thx!!!!!
Tony
