Tie down straps
- dreamer
Tie down straps
I'm picking up the
tomorow morning. I think I've got the Durango all set. It's only about an hour drive. I told the dealer the only thing I needed was a strap going around the back over the cockpit to keep the boat snug to the trailer. He recommended against it, saying that the boat is custom made for the
and supports it well and that when you go over bumps with a tie down strap it lifts the trailer and you feel alot of jerking in the vehicle. I can see what he's saying. What do you guys think?
- dennisneal
- NiceAft
I think your dealer is out of his mind
How about taking a turn too fast and the boat rolls off of the trailer? How about slamming on your breaks because of an emergency situation, and the trailer slips and slides? What keeps the boat on it?
So what if you take a bump and everything goes up and down. You quickly learn how fast you can safely go.
Here is what I use
It was recommended to me by Kevin, and I'm glad I listened to him. It wraps all the way around the boat at the forward part of the cockpit. Because of the rise at the front of the cockpit, the boat can not slide backwards if the bow breaks free from the winch.
P.S. I just took this picture a few minutes ago. It's dark out, and the flash is only good for so many feet, so please excuse the darkness of the shot. I wanted to show more clearly where I place the strap.
Here is what I use
- dennisneal
Boblee
LOL Dennis I think Ray was reffering to Dreamers dealer.
If you have any doubts about whether a strap is needed just get someone to tow the boat up the road while you sit behind, anything but smooth bitumen will have it lifting right off the trailer.
I use straps but tie them down to the trailer, my only problem has been black marks on the boat from the straps flapping.
- NiceAft
Dennisneal,
I can understand why you thought I was referring to your post, I wasn't. My apologies.
I was so struck dumbfounded by the thought of a dealer recommending something so dangerous that I skipped identifying who's post I was responding to.
Boblee,
The type of strap I showed in my post does not leave any marks. It is a wide strap that secures very well.
I was so struck dumbfounded by the thought of a dealer recommending something so dangerous that I skipped identifying who's post I was responding to.Boblee,
- Captain Jim
- Location: Fort Miller, N.Y.; "BOLD VENTURE"; 2006 26M Blue ; 05 Honda 50Hp 4 S
- Captain Jim
- NiceAft
I can't go and measure the length today, but here is a site that sells the ratcheting strap.
This site also sells a 3" ratchet strap with J hooks. http://www.uscargocontrol.com/ratchetstraps3-c-5.html
- Oskar 26M
Tiedown straps are essential for towing any distance. I use three, all quick release rachet types similar to those shown in the earlier posts: one on either side through each of the stern cleats then slightly forward to the trailer (pulling forward helps to keep the 26M's bow firmly in its rubber buffer on the trailer); and one passing through both bow cleats and around the trailer frame. I fit the straps after doing the Mac bump to seat the boat firmly into the trailer, then check their tension every so often whilst towing. They take very little time to fit and seconds to remove.
Don't forget to take the tiedowns off before launching though! Its easy to forget if you are feeling under pressure at a busy ramp. If you are launching in a cross wind both boat and trailer will drift sideways and really make you look like a novice! You'll only do it once ...
Dunno if these pics will work, havent tried to post pics before:
