Where do you mount your bi-colour nav. light?
Mine was (operative word) mounted on a wooden block that raised it up from the original deck level so it was not obscured by the roller fitting.
However, while raising the anchor yesterday the rode slipped sideways off the roller (the boat was pulling to the side because of wind and current) and swiftly took the light with it.
So before I go out and replace it directly, I'm thinking of a better place to locate it. Somewhere on the pulpit rail would seem a better idea, provided I can make or obtain a decent mounting, and allowing for routing the wire etc.
I'd like to stick with an AquaSignal 20 light, as they seem to be the only ones that use a 5W rather than 10W bulb, but they're only made with a base mount so some kind of bracket would be needed.
Just wondering what others do - or do you all just manage to be more careful with your anchors
Rick
