Mast head light M not working
- Andy hipetrol
- Location: Lake Travis Austin, Texas 07 26M 50HP Tohatsu
If Mast head light quits working on an M in a freshwater slip and it is not the fuse is it more than likely the light bulb, or the connection at the base of the mast?
After searching this website the consensus for an X it was most likely the connection at base of the mast.
Anyone else have this problem and what were the solutions?
- Andy hipetrol
- Andy hipetrol
LOUIS B HOLUB
Ive had the following separate issues with my mast running light. These have occurred more than once. We keep our Mac in a slip also.
The bulb wasnt seated well, and with a twist it lit up, and a few occasions,
I cleaned the deck brass plug tips, and the light lit up. (I use a short light duty alum. ladder tied to the mast to reach the bulb, knowing full well that the Mac will "lay over" if one climbs too high on a Mac mast). Using a short ladder is much easier than dropping the mast to access the bulb for the mast running light.
My deck plug has an opening where the wires are threaded through, and moisture previously could easily seep through the plug. Ive used some Dupont Silicone on top the plug, and moisture is no longer a problem in corroding the connections.
- c130king
15% cheaper on Defender.com.
http://www.defender.com/product.jsp?pat ... &id=846701
I can't seem to get Defender.com links to post correctly.
- Andy hipetrol
I did not think I could reach the light with a ladder, but will try that first.
We left a restaraunt on the lake late Saturday night and of course that is when I tried the lights and that one had quit working.
I really have not had a chance to fix other than Saturday night I was able to check the inside cabin fuse and it looked ok, so it must be the connection or the bulb.
Louis my boat came from Kemah I stayed at Yacht Harbor when I picked it up. I'm pretty sure I saw and X when we were admiring all of the boats.
Andy
Andy
- tangentair
Jim - If you are going to replace the plug order a 4 prong model - it is the same size and current capacity etc, that way you have spare connectors for a second circuit or if you break one.
Andy - please have you wife video you climbing a ladder up the mast to change a light bulb. If not for the ammusment value at least for the insurance claim. You really can not imagine until you have been there what a 150-200 lb weight on a 20 or so foot arm can swing like.
he is tied off and we were just bringing him down, the boat has 6000lbs of lead in a full keel and I had to get off the boat to take the picture it was rocking so much.
Has anyone tried to use a jib halyard or topping lift to pull the boat over next to a dock/slip to reach the steaming light? Dumping the ballast should let it lay over, or at least enough to reach the lamp from a ladder on the dock.
That seems to be an easy way to reach it, or am I missing something?????
Ron
Ron
- Andy hipetrol
