In use
Ours takes all of 10 seconds to do and is very easy.I have the little bracket to unhook the motor. Only did it once though, a real PITA if you ask me.
As for disconnecting being a bad Idea you just have to remember to have at least 1 rudder down and a touch of centerboard fo the boat to pivot around and it is very controllable. The only gain from the motor being connected I can see is prop walk when docking (to snug against the pier when docking)
