Water ski or Wakeboard ?
Locked
MarkStanton
Post by MarkStanton »
So having sailed loads and had great fun I am think of taking the plunge and buying either Water Skis or a Wakeboard. (Second Hand)
Having never tried either in my entire life (but I am a faily good snow skiier) is it easy to just give it a try ?
I know the Mac (I have an :macx: ) is slow for this but I am told it is possible.
Can anyone tell me if Skis or boards are better ? (for a Mac)
Any tips
What speed to down need to go to get up on either ?
How did you attach a tow line ?
Thanks, Mark
KRV
Try a knee board
Post by KRV »
Maybe a Knee board (different than wake) might be the best thing to start out with. It might be difficult to get up on skis ort a wake board due to the power needed to lift somone out of water. Maybe someone with a lot of experience water skiing could get up behind a mac.
The knee board is something that is a lot easier to do and could be a great starting point if you never have been towed before. Be careful and make sure there are 2 people in the boat. 1 to steer and the other to hold the flag (orange) when you inevitably wipe out! The Mac will pull you nicely on a knee board.
Duane Dunn, Allegro
Post by Duane Dunn, Allegro »
We've used three out of the four choices for water toys behind the mac.
Inner Tube - If you lay flat, rather than sit you will find this can be fun even at mac speeds. A steerable tube would be best. Our's isn't and we miss the extra control. Also one with a open back is much easier to get into from the water than a regular one like ours. This is the simplest water toy, fun for little kids all the way up through adults. Since it's attached to the boat it's the easiest to use as well. The rougher the water the better. It's a good choice when the water gets to rough for the other three or you get too tired.
Kneeboard - The mac is a good kneeboard boat, just slightly slower than what advanced people may want but plenty fast for beginners. Riding a kneeboard takes some skill, in particular getting from the prone start position to the kneeling one can be a challenge as you mess with the strap and still try to hold on. A hint, keep both hands on the rope and use your elbows to lever yourself up to your knees. Once you are up, move to going outside the wake and the doing spins and even rolls.
Wakeboard - The water version of a snow board / skateboard. You stand sideways on it. The mac speed and wake are good for all but the advanced jump and flip crowd. This is the one I have not tried.
Waterskis - In general the mac is too slow for all but beginners. However, just over a week ago I did go out and ski behind mine. I was on two skis and the boat has plenty of power and punch to pull my 180lbs out, I popped right out with no problem. The ride is just fast enough to stay up on a plane. Lighter people would have a better time. Get the widest skis for the easiest time. I was on a pair of matched slalom skies with the concave bottom. These are easier to control then the usual cheap flat bottom beginner skis. Small kids might be able to ski behind the mac on a single ski, but there is no way an adult could, the boat is too slow.
You will also find that getting the rope back to a person is the water is harder than in a normal ski boat. The mac doesn't circle tight enough. It's easier to use the fly by method. Drive right at the person. Just before you hit them turn to one side then back to the other so you jog around them and end up back on your original course line. This will bring the rope to them.
Mark Prouty
Re: Water ski or Wakeboard ?
Post by Mark Prouty »
MarkStanton wrote:So having sailed loads and had great fun I am think of taking the plunge and buying either Water Skis or a Wakeboard. (Second Hand)
Any tips
Thanks, Mark
The kids have tried wakeboarding. You have to start sideways. The trick is to turn board straight shortly after startup. Lots of fun. Kids like it better than skiing. My boat has a little bigger engine but if you can ski behind a Mac with a 50hp pulling Duane, :o you can probably wakeboard.
Just wrap the line around one of the back stanchions and tie it to a rear cleat.
Don B
Post by Don B »
I agree on using wide skiis. Maybe look for some used ones at a Garage sale.
Some one suggested to me to use the cleats on the back to tie a tow line to.
Other people have installed a tow eye.
Good Luck !!!
-Don B
All this discussion has got me to thinking back when I was a kid and I lived in Lavina, TN... we used to go up an waterski on the Tennessee River every few weekends or so... but my mom had Multiple Sclerosis, so she couldn't ski like we could, and we felt bad for her not being able to participate... so one day my dad and I hauled down the door off the old barn (it was falling down anyway!) and set it up with a rope that she could hold to and then dragged it behind the boat - she was able to stand up and hold on just fine and she had the time of her life on that thing... I can still remember her laughing nearly the entire time she was on it....
Sigh.
Locked
