M mast cost??
albion
Location: Medina Ohio 2007 Mac26M Suzuki 50hp Hull#M1494g607
M mast cost??
Post by albion »
How much does a new M26 mast cost? Mine has a bend in it. Has anyone ever had one straightened.How was it done?
Boblee
Re: M mast cost??
Post by Boblee »
Is it a bad bend and is it to the side or fore/aft.
bastonjock
Re: M mast cost??
Post by bastonjock »
albion,ive been quoted 450.00 pounds for a new 26m mast,as far as sraightening a bent one goes,that all dpnds on how badly bent the mast is
Terry
Re: M mast cost??
Post by Terry »
I paid $2000.00 for a new M mast in 2004, could buy a trailer for that much! :o
bscott
Re: M mast cost??
Post by bscott »
Only a dealer can answer that as the shipping cost has alot of influence on the price. If you are lucky your dealer can include a mast in the delivery of new boats.
Bob
bastonjock
Re: M mast cost??
i was quite surprized at the quote,mind you if you have to include rigging that doubles the price
delevi
Re: M mast cost??
Post by delevi »
I don't think that would be the case. I paid something like $60 for a new 5/32" foorestay.. so add 4 shrouds and you're at $300.
Dimitri-2000X-Tampa
Re: M mast cost??
Post by Dimitri-2000X-Tampa »
I think I paid under $500 for my X mast, but i did have to wait a couple months to have it shipped for free with a new boat. M mast is slightly larger of course, so probably costs more.
AWKIII
Re: M mast cost??
Post by AWKIII »
We frequently get calls for new masts and the major problem is delivery.
A 26M mast is two or three feet longer than the maximum shipping length most commericial carriers will handle.
We normally get one up at the factory when we are picking up new boats and bring it to our Colorado location. A buyer will then drive here to get it or we will ship it with a new boat delivery assuming we have one in the general area.
You could try some of the freight aggregators like uship but I understand the cost can really get expensive.
Art
EricM26
Re: M mast cost??
Post by EricM26 »
My mast bent in 2006 when one of the pins holding the aft starboard shroud worked its way loose from the chainplate while sailing. The mast fell to port; when it hit the water the mast bent 60 degrees at the spreader. I called MacGregor and several dealerships in my region, Potomac to see how I could acquire a mast. Fortunately for me some poor soul in Urbanna VA had his M26 dashed up against the rocks in Hurricane Ernesto. It cut a 6' x 1' gash in his hull. The insurance company totalled it, but his rigging was intact. One of the dealers heard about it and put him in contact with me. I bought his mast for $500 and hauled it up on my trailer. Perhaps there are still some Katrina, or other hurricane, damaged MacGregors around that may have a viable mast? Good luck and remember to tape your pins!
Dimitri-2000X-Tampa
Re: M mast cost??
After having a couple shroud ringdings torn off by genoa sheets in the first year or two, I turned all mine so that the ring ding faces in. Haven't had any more come off now in a few years since I did that. Shrouds are tearing up the sheets though. Perhaps I need to put some rubber hose around it since I think the prefabed ones you normally see on sailboats only fit around turnbuckles.
Terry
Re: M mast cost??
Post by Terry »
As Leon said, a new 5/32 forestay only cost me $60 too, but I got a 5/16 turnbuckle to compliment it so I paid an additional $40.
I also have those pre-fab turnbuckle covers that Dimitri mentions even though my turnbuckle tops and swages are covered with tape. The white PVC covers with caps protect the whole ensemble from wear and the sheets never get caught on the ringdings. I am not sure I would put any long lengths of hose or tubing up my shrouds as that would only create more windage drag on my shrouds. Maybe just a bit more tape wound higher might help.
Bill Warnock
Re: M mast cost??
Post by Bill Warnock »
Back in March 2006 Rich Boren and I went to the Costa Mesa factory and purchased a
new mast and related components for our 2004 26M. Here are the invoice details at
that time:
Mast (Drilled & Spread) $ 480.00
Mast Hinge-Mast Base Plate 51.00
Mast Hinge-Mast Bottom Cap 36.00
Spreader Bar with Tip 44" 24.00
California Sales Tax 45.80
Bill
Anacapa Isle Marina Slip A-21
Channel Islands Harbor
Oxnard, California
Boblee
Re: M mast cost??
Post by Boblee »
Re the covers for the chainplates I just use some clear 1" plastic hose but this does discolour and for the shrouds you can buy split pvc tubing that slips over them, this also helps on rub points when trailering to.
Kaceys ' Charm
Re: M mast cost??
Post by Kaceys ' Charm »
In July I paid $2400 for new mast, spreaders, shroud lines and extrusion for my rf. I found a dealer who always buys two extra masts with every boat for such problems (Dowser Marine in Hamilton Ont). I was lucky to find him because RCR yachts (who my insurance adjuster wanted me to use)was going to charge me $1500 just to ship me a $1000 bare extrusion and all other work would have been extra. It also would have taken 2.5 weeks for delivery. Plus my adjuster didn't want me using the boat without the mast on and repair work finished.
