Ever since I slipped my boat last July, I noticed that it lists to port about 3-4 degrees. At first I thought it was my imagination, but even when underway, in calm water, it still lists. I am planning to bring my boat home to do some work on it, so yesterday I went and removed everything that was stored on the boat. I thought that maybe all my "stuff" might be the source of the problem. Well, with everything out, except the basics, it still lists. I even brought my 4' level and placed it across the hatch opening, and yep, she lists.
I went over the boat trying to figure what would cause this problem, but I cannot identify any one thing as the source. I have two batteries under the aft galley seat, with an isolator and Guest battery tender, but then I have my two spare anchors under the forward dinette seat. I also have my starter battery mounted at the very rear of the aft starboard bunk. All the cushions, food and supplies have been removed. My spare sheets and halyards are stowed in the head. That's all that is on the boat.
Anyone have any ideas, or is this normal? BTW, the ballast tanks are full, according to the vent hole. Could I have a ballast tank problem? Out of habit, I check the ballast before I use the boat by opening the vent and opening the fill gate, so the ballast has plenty of time to fill. I'm lost
Pat
