Water? Drain?
Andy26M
Chain Locker
Post by Andy26M »
The term "chain locker" comes, afaik, from larger ships. For most people, I think the term "locker" brings up an image of a small cabinet, such as your high school gym locker. But for shipboard sailors, the term "locker" brings up an image of a full sized room used to store things. Boatswains locker, Repair locker, etc.
A typical Navy ship has 13 Shots of anchor chain (1 shot = 15 fathoms = 90 feet, so a total of 1170 feet of chain - there is no rope rode). The links are from 4" to as big as 12", depending on the size of the vessel.
As you can imagine, when the anchor is up, all that chain has to go somewhere - and it all leads down through the "hawse pipe" into a room called the "chain locker". It is not an "anchor locker" because the anchor is stored hanging outside the hull of the ship, not inside. On my last ship I recall (it's been a long time so no promises) the chain locker being about 20 feet square and two stories tall inside, and when the chain was all in, the locker was nearly full.
On our Macs, we call the little cabinet in the foc's'le (foc's'le is a contraction of forecastle) deck an "anchor locker" because the anchor is actually able to be stored inside it :wink:
Andy
Andy26M
Re: Water? Drain?
Post by Andy26M »
I don't know about 26X's or the newer M's, but in my 2004 26M I have no real place to mount a bilge pump that would make much sense. Any water tends to collect centerline forward, just aft of the daggerboard trunk, where there is only about 2" of space under the cabin sole.
I keep a hand-pump on board to pump water out of there if I get any, in order to be in line with Coast Guard minimum safety guidelines, but in actual practice I use a small wet/dry vacuum and just suck the water out through the two holes in the cabin sole (usually hidden under the carpet).
Andy
Re: Water? Drain?
Post by Kelly Hanson East »
Are you not required by law in your area to have a bilge pump of some sort with a min. capacity requirment ! I know in Canada we do for coastal & lake boating
No such requirement in the US of A
EasyLuckyFree
Re: Water? Drain?
Post by EasyLuckyFree »
Good Stuff..
Thanks for all the comments.
